Thread: Automatic Garage Door Opener
Created on: 12/19/09 12:00 AM
slidderhd
slidderhd's Gravatar
12/19/09 9:44 PM
I took the Garage Door opener off my Harley. I need help attaching it to the Ninja. Switchingthe Headlights back and forth initiates the door opening. The transmitter has a Black Ground, White High Beam, Yellow Low Beam, and a Orange/White Wire that is a Power wire I would like to only be hot when the key is on. Where can I connect to the harness in the front Fairing of the Ninja?
Riding for the Son!
Its not about us, its about Him
RE: Automatic Garage Door Opener
12/19/09 9:58 PM
I recently had the horn recommended as a good hot wire. I was not able to use that location because my accessory was under the seat.
slidderhd
12/23/09 8:29 PM
Bgordon, can you please move this thread to the Ask Hub folder? He probably knows the wiring well enough to help.
[Done. -bg]
* Last updated by: bgordon on 12/24/2009 @ 7:51 AM *
Riding for the Son!
slidderhd
12/27/09 11:00 PM
Thanks Hub.
Riding for the Son!
slidderhd
12/30/09 1:09 AM
Ok, I just had a failed attempt of connecting the garage door opener from Harley. I realized halfway through the install that for the Harley transmitter to work, the low beam has to turn off when the high beam comes on. As you guys know, the Big Ninja's low beam never turns off.
As for the wiring, I followed Hubs reference and it was right on. Instead of using the BR/BK, I just used the running light hot wire that was in the same bundle as the headlight wires. I verified the power outputs with a volt meter and all looked good. As expected, the transmitter didn't work. I guess I will install it in the wife's car. Thaks for your help.
Riding for the Son!
slidderhd
01/01/10 12:27 AM
I figured I would just get a switch and just simulate the head light action. Thanks Hub.
Riding for the Son!
Sharkey
Sharkey's Gravatar
Grass Valley, CA
01/04/10 2:26 PM
I velcroed my garage door opener to my tank bag. Fow power I used an AAA.
Removed GPS.
harleyxlc
01/09/10 9:28 PM
slidderhd, I had my local shop do it while they were giving the bike a once over. And of course, they ran into the same issue you had...the low beam never goes off.
They installed it and it works....would you like me to get some details from them? They will be open on Tuesday.
slidderhd
01/10/10 11:43 PM
harleyxlc, that would be awesome. Thanks.
Riding for the Son!
harleyxlc
01/11/10 6:41 AM
I'll call them on Tuesday.
harleyxlc
01/12/10 1:27 PM
From the shop...
"One lead to the high beam and the other to a ground."
slidderhd
01/13/10 8:21 PM
I will try it as soon as the garage thaws out.
Riding for the Son!
